95 Civic EX Motor Swap
I hava a stock motor still and was wondering which would be better to put into my civic. I am torn between the B16A and the B18C, which would be better cost and labor wise. I wish I could do the work but I don't have the tools or shop to do this. I found a guy who wants to do it for me but still want some opinions? The car is already dropped 3" if that will play a part in motor selection.
Re: 95 Civic EX Motor Swap
^^That. If you have to go b series, I suggest a B18c1 or B18c5 if you can afford it. Otherwise, raise ur suspension up a little and go H22.
I ewill see about a b18c but I dont want to touch my suspension it handles great right now but i know that can change with a different motor.
The Grumpiest
Did you not ask the guy that's going to do the swap? Check the FAQs at the top of the page and read up on what goes into swapping one of these engines.
ummmm u dont need new mounts u can use ur stock d series mounts on the gsr aslong as the gsr is a complete swap it will drop right in and if u get the jdm engine make sure u get a jdm ecu just less of a headace
Booom!! just did this swap a 2 months ago
lol hes talking about a 95 CIVIC not a 96-00 civic a gsr motor will drop right into a 92-95 civic the only difference is the rear t bracket , if hes buying the swap the swap will come with all the mounts and will drop right in its basically plug and play
if you can afford the B18C1 get that one, it's a way better platform to start out with. A B16A feels like a sohc until you open vtec, and even then its not very impressive.
/thread
/thread
The best "bang for the buck" would be a B18C1 as well as a GSR tranny. If you can spend a lil more get a JDM tranny with LSD, If you want to get the best possible B series setup get a JDM b18c 98 spec with the LSD tranny.
Unless you can get an amazing cheap deal on a B16 id avoid it. The B18C1 C5 and C are top choice.
Thanks guys a lot of good ideas but looks like everything is pointing to me finding a B18C and LSD trans for a nice price. Where can you find good deals... Junkyard if so I will build the motor how I want. Suggestions for internals next!
Well I want to find one around $1200 and as far as the jukyard goes as long as the head is ok I hope its fine. Like I said I want to rebuild the internals before I even do the swap so I know everything inside will last.
