removing AC controls from EK --- please help
I can't disconnect the cable from the back. its the cable that connects to the sliding thing from cold to hot. 96 civic EX
thanks
thanks
Re: removing AC controls from EK --- please help (Philip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip »</TD></TR><TR><TD CLASS="quote">I need to remove it from the dash. it's a long story.</TD></TR></TABLE>
Oh. Well then your best bet is to carefully, pull the center dash out and remove it that way. I dont know of a way to remove it without taking it all apart.
Re: removing AC controls from EK --- please help (VTEC-DA)
i've got the center dash coming out. everything is in pieces. i just can't get the dang cable to come out the back of the ac control unit so it will be free. once that is disconnected it will come right out. i just don't know how the cable disconnects.
thanks
thanks
if you reach your fingers and feel the harness, you should be able to find a tab that keeps the harness clipped in. or follow the wiring harness to the bottom and detach it there so you can pull it all out.
Re: removing AC controls from EK --- please help (mugen76)
disconnect it from the heater box, its easier.
Re: removing AC controls from EK --- please help (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">disconnect it from the heater box, its easier.</TD></TR></TABLE>
i just discovered this on my own like 5 min ago! i came here to let you know about the trick. thanks anyway
305_DB7ish
03-25-2015 12:52 AM
