Which Sways will fit?
Old 06-01-2003, 10:42 PM
Touch's Avatar
Default Which Sways will fit?
Will OEM sway bars fit an EG with a neuspeed lower tie?
Old 06-02-2003, 12:27 AM
eg6sir-s's Avatar
Default Re: Which Sways will fit? (Touch)
which oem sway are you refering too? gsr or civic or itr?
Old 06-02-2003, 09:28 AM
Touch's Avatar
Default Re: Which Sways will fit? (eg6si)
will either fit? 14mm or 22mm
Old 06-02-2003, 11:07 AM
Touch's Avatar
hello?
Old 06-02-2003, 11:11 AM
Jackson's Avatar
Yes, the front and rears bolt up. You will need gsr or itr rear lca's to bolt up the endlink. And if you get itr lca's you will need the itr shocks or some other shock meant for an itr. You will also want some kind of reinforcement for your subframe. You can either make your own with washers and plates or get a beaks kit a http://www.beaksproducts.com.
Old 06-02-2003, 01:08 PM
Touch's Avatar
Default Re: Which Sways will fit? (Jackson)
I have gsr rear lcas. with the 14mm bar what els will I need?
Old 06-02-2003, 01:45 PM
Boba Connoisseur
SkyeC's Avatar
13mm and 14mm swaybars work fine with a lower tie.
You will run into problems with an ITR bar and SRK's because of the reinforcement plate.
I believe the solution is longer bolts for the LCA. He sells 'em for 10 dollars.
abolish415
10-03-2003 12:08 PM
RedGSR
10-02-2002 10:12 AM
comptechgsr
09-15-2002 12:00 AM
Mr. Softee
01-25-2002 06:22 PM
DreamSpeed
12-04-2001 07:16 AM
Quick Reply: Which Sways will fit?
