LCA question
LCA question
I need sway bars on my vx because this thing is scary going at high speeds and the car is not too safe. I can lose control of it too easy and not safe to drive around like this. so my question is could i get a 92-95 lca's from a si hb or ex and put them on my vx and then add some aftermarket sway bars on the front and rear?
Re: LCA question (GReddy SI)
You don't necessarily need the LCA's from an EX or Si. I have a Suspension Techniques rear sway bar that works with any 92-00 Civic, since it does not use stock mounting locations. Did the 92-95 EX Civics have rear sway bars at all (I know the 96-00 don't)?
Re: LCA question (Touch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touch »</TD></TR><TR><TD CLASS="quote">92-95 civics don't have rear sways. sure of it.</TD></TR></TABLE>
92-95 coupes and hatches did not have rear sway bars.. 92-95 civic sedans did.. if you want to put a rear sway bar on your VX i would get a set of 94+ integra rear lca and you can bolt up a gsr or itr sway bar... btw, i love my JDM ITR rear sway bar..
Re: LCA question (Hybrid95CivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX »</TD></TR><TR><TD CLASS="quote">
92-95 coupes and hatches did not have rear sway bars.. 92-95 civic sedans did.. if you want to put a rear sway bar on your VX i would get a set of 94+ integra rear lca and you can bolt up a gsr or itr sway bar... btw, i love my JDM ITR rear sway bar.. </TD></TR></TABLE>
Not all 4dr's, just the ex's. If your going about it the cheap way you minght
want to get a 14mm gsr rear bar and you wont have to buy the beaks kit.
dont get the wrong idea about sways though. a good setup for you would be a 19mm ex front / gsr lca + 14mm gsr rear / teg lca.
22mm rear isnt fun at high speeds either, even with a 24mm front.
= 92 teg lcas should be anywhere from 60-100 depending on where you get them from
if you need the front... i have the suspension techniques front sway bar for 92-95 civics with no front sway bar for $75+shipping(if required). what is your location?
h-t member kgrcr1 has the rear suspension techniques sway bar for sale.
p m me if you have any further questions.
allenp
14
08-03-2006 01:46 PM
