oil pressure gauge problem
Has anyone had problems with autometer electeric oil pressure gagues? Mine worked for about a whole 3mins yesturday when I got done hooking it up and I can't find what could be wrong with it. Any ideas the wires are all good. thanks
Re: oil pressure gauge problem (g unit)
the sender is mounted right off the back of the factory oil sending port with a T fitting. The sender has no ground on it. I played with it last night and I thing the sender my be stuck so I'm going to call autometer to see if I can't get another one. but if anyone has any ideas give them to me
Re: oil pressure gauge problem (grey16)
I had the same problem It ended up being the ground.
Just run a piece of wire from the sender case to a good ground and see if that helps. Good luck
superhatchbackbros
07-28-2006 05:47 PM
