Proportioning valve help..
Okay, I'm fixing and replacing some stuff from my rear disc swap I did a year ago (new SS lines, SI parking brake lines, new pads/rotors) and I'm trying to figure out if I need a new proportioning valve. I've checked part numbers on hondaautomotiveparts and this is what I found:
'98 3DR DX
22522 004 1 VALVE, PROPORTIONING NO COLOR 97.93 73.45
'99 2DR SI
'00 2DR SI
220473 004 VALVE, PROPORTIONING NO COLOR 97.93 73.45
From what I can see.. mine and the '99 SI one are the same, but both are different from the '00 SI. I'm wondering if anyone happens to know if I need to change it out.
'98 3DR DX
'99 2DR SI
'00 2DR SI
Re: Proportioning valve help.. (CRX25)
How about the hard lines? The lines running from the master cylinder to the prop valve and prop valve to the brakes.
Can the original lines be reused? or do those have to be swapped out too with the new prop valve and master cylinder? For instance ... 99-00 Si into a 96-00 DX.
Thanks.
JLi
Thanks.
JLi
Jonathan_ED3
03-24-2004 02:50 PM
