throwing code 3 - map sensor defective??
Old Jun 1, 2003 | 07:27 PM
slowazzhatch's Avatar
Default throwing code 3 - map sensor defective??
after i drive the car a while the CEL will come on and it flashed 3 short time - map sensor - bad wiring or defective map sensor - when the CEL is on it idles about 1300-1400 or so and wont go any lower even if i cut the AC on - what could this be - i also back fire alot when this code is on...help me out here guys
thanks
Matt
Old Jun 1, 2003 | 07:29 PM
smnowell's Avatar
Default Re: throwing code 3 - map sensor defective?? (slowazzhatch)
I would replace the MAP sensor. I had the same problem, except it happened immediately. As soon as I turned the car on, it would idle real high and lumpy. CEL came on as soon as the car started and it was code 3 as well. I replaced the MAP sensor and that fixed my problem
Old Jun 1, 2003 | 07:32 PM
Default Re: throwing code 3 - map sensor defective?? (b16a ferio)
well the CEL is coming on now for as soon as i start the car - thanks man
but here is my ? to u
i have a 1st gen b16a - on a obd1 p28
what map sensor should i get - or they all the same?
i'm retarded when it comes to map sensors...
Old Jun 1, 2003 | 07:38 PM
smnowell's Avatar
is yours on the throttle body or bolted to the fuel filter/firewall? Whichever type yours is, just get that kind. You could probably go to the junk yard and find yourself a few MAP sensors to take home and try out and keep whichever one works
Old Jun 1, 2003 | 07:42 PM
mines on the TB - well the top of the TB - go get me a few map sensors and see which one works huh, not buy a new one..??
hey b16a ferio - im me i've g/g - i'll get back to you in a bit
hondalove414
Mar 20, 2011 08:11 AM
92ehatch
16
Feb 19, 2007 11:41 PM
Punker1234
Feb 4, 2006 01:20 PM
chrysler kid
Sep 28, 2004 07:24 PM
