d16y8 in del sol...PLS HELP ASAP!!!
Old 06-01-2003, 08:35 AM
TKL
TKL's Avatar
Default d16y8 in 94 del sol si..PLS HELP ASAP!!!
I need some seriously help...I ran into some problems last night doing the swap in my car...its a complete d16y8 swap (OBD II to OBD 1) and I had everything converted over but the rear mount..its seems to be short about 1 inch.I had to changed the driver side mount and left the other mounts the same. Pls help so i can complete this.any help is appreicated!!!
thanks
Modified by TKL at 9:50 AM 6/1/2003
Old 06-01-2003, 09:02 AM
clm
clm's Avatar
Default Re: d16y8 in 94 del sol si..PLS HELP ASAP!!! (TKL)
Is it an automatic to manual conversion? I think I recall reading soemthing about the transmission mount not being the same.
Old 06-01-2003, 09:09 AM
TKL
TKL's Avatar
Default Re: d16y8 in 94 del sol si..PLS HELP ASAP!!! (clm)
no its a 5 sp swap.
Old 06-01-2003, 11:33 AM
vladd's Avatar
are you using the del sol mount or y8 mount for the back one? the stock one should work, or at least that's what i've heard.
Old 06-01-2003, 11:41 AM
B.
400 HP Club
B.'s Avatar
Default Re: d16y8 in 94 del sol si..PLS HELP ASAP!!! (civicdxtyper)
just wondering why you would go through all that to put a d16y8 back in?
Old 06-02-2003, 03:00 PM
TKL
TKL's Avatar
Default Re: d16y8 in 94 del sol si..PLS HELP ASAP!!! (THE B)
the bottom end went out on the z6 so i decide to go with the newer motor. I changed the mount to the z6 rear mount and it worked.thanks everyone.
MichaeltsinEF
11-18-2018 08:42 PM
sterlihs
08-12-2013 07:13 PM
xmod
04-01-2009 11:25 PM
H22AJSPEC
02-22-2006 05:47 PM
BoostedEgHatchFl
05-21-2005 03:44 PM
Quick Reply: d16y8 in del sol...PLS HELP ASAP!!!
