ITR pistons in GSR?
ITR pistons in GSR?
Like the title says, just curious if ITR pistons/rods would fit into a B18C1. I assume it would, but just want to make sure before I dish out the $$. Thanks in advance.
Re: ITR pistons in GSR? (Emerika)
Pic is from the movie, "Stealing Harvard"...in the movie Tom Green says, "I wanna be Steve!"...just thought it went together, and walah!
Thanks for the info on the B16 pistons, what did you mean by CR though??
Re: ITR pistons in GSR? (I wanna be Steve!)
compression ratio
use this site to figure what compression you get with certain pistons.
http://www.c-speedracing.com/h...c.php
usdm itr pistons: 10.8 to 1 cr
usdm b16 pistons: 11.3 to 1 cr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">HAHA, what is that Tom Green pic from?
Edit- I heard using B16 pistons will yield a littler higher CR </TD></TR></TABLE>
any b16 pistons? really? how so. can you explain that? thanks.
Re: ITR pistons in GSR? (Soup ****)
yes any b16 pistons.......will yield a higher compression becuz they are
more domed than itr pistons. if you use p30 b16 pistons you will get even
more compression.
more compression.
1 Post
Re: ITR pistons in GSR? (djhatch)
PR3 pistons yield the same compression as JDM ITR Pistons if I recall...
PM Trey about this, he has had both of the piston setups...
stonet149
12
11-02-2008 09:29 PM
