96-00 EJ6 exhaust question
When i buy a fullcat-back for my EJ6, it will bolt up. But, the cat for my car is under the hood. so when i swap the motor, will the exhaust still bolt up with if i put a cat there ? or will i need to get the exhaust cut or something? i was curious about this for a while. i was thinking maybe because the cat was under the hood, the exhaust mani goes a longer distance before hitting the exhaust piping, as opposed to say a d16y8, or a b series swap.?
Re: 96-00 EJ6 exhaust question (JUN EK9)
if you have an ex coupe, the exhaust will bolt up witha b16 no prob. i went from ex exhaust connected to ex motor, then to ex exhaust connected to si motor (b16a2), then si exhaust to si motor. what i mean is, any exhaust for ex/si will be fine.
if you have a dx/cx/hx etc, i'd wait to buy exhaust until after you have motor.
Re: 96-00 EJ6 exhaust question (ruthless013)
If you have a D16Y7{ie DX} (which im guessing you do) you will have to buy an exhaust made to fit that engine. I would suggest going ahead and getting an exhaust for the EX/SI and then just putting the factory exhaust manifold (header) from an EX on your car. That way if you ever swap your engines you can keep you exhaust. Rick
ELIT3
09-25-2009 02:39 PM
