swapped in d15b7, won't start!! need help!!
here's the deal. I just finished swapping in a d15b7 into my brother's 93 CX. car has been sitting for about a year and so has the motor. the car cranks but doesn't want to turn over. I reused the CX harness. MAP sensor isn't hooked up yet, but does that even matter right now? No CELs right now either.
here's the things I've done so far.
replaced: dizzy cap, rotor, plugs, new battery.
I know fuel is getting to the motor cause when I pull the plugs, fuel is dumped all over all of them. the car has been sitting for almost a year now with less then 1/4 tank of gas. could the gas be bad? I added 2 more gallons on top of the gas that has been sitting in the tank.
Dizzy is fine, checked the igniter with a volt meter, checked the internal coil with an ohm meter, both came out to specs. I also pulled each plug wire one by one and stuck a screwdriver into them and grounded it out while cranking. I was getting a spark on all 4.
I'm going to do a compression test as soon as I can get a hold of one.
what else should I check? I'm at a loss...help of any kind would be nice. thanks in advance.
thanks for the helping out.
I'll double check my grounds tomorrow. I'm freezing my *** off and it gets dark, fast now. how many main grounds should there be and where?
The guy I bought it from said it was running but would ocasionally smoke when you hit WOT. he said he passed emissions with the motor.
I tried cranking it again and it sounds like it wants to turn over but won't. I'm still at a loss...
hooked up the MAP, ran a vaccum line from the MAP to the throttle body and hooked up the connector. still no start...dang, starting to get frustrating!!...any more suggestions?
new dilemma. so I try push starting it earlier. no good. anyways, I push the car in, try to start it again, now it sounds like the starter is screwed. when I try to start it, the starter just sounds like it's spinning and not catching the flywheel. just spins and spins. ****...so anyways, I put on the old CX starter. when I go to crank it, the motor sounds like it's really struggling to crank now. man, so what do you guys think? bad motor? ****...
Re: (Honda Sport)
im gonna go w/ gas. Year old gass breaks down and dosnt work so well. Try draining the tank, taking out your spark plugs for a night to drain the cylinders, and fill 'er up w/ about 2-3 gal's, then see what happens
Re: (Apocolipse269)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apocolipse269 »</TD></TR><TR><TD CLASS="quote">im gonna go w/ gas. Year old gass breaks down and dosnt work so well. Try draining the tank, taking out your spark plugs for a night to drain the cylinders, and fill 'er up w/ about 2-3 gal's, then see what happens</TD></TR></TABLE>
will try that tomorrow. how would I go about completely draining the tank? is there a drain plug on the gas tank?
just a side note, before the starter went bad, when I cranked it, it sounded fine, just didn't wanna turn over. now, the motor sounds like it wants to seize.
Re: (Honda Sport)
sounds like the timing belt skipped a tooth or 3.
other than that what ecu are you running? the p05 from the cx or the p06 from the b7?
Re: (Bakeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bakeoff »</TD></TR><TR><TD CLASS="quote">sounds like the timing belt skipped a tooth or 3.
other than that what ecu are you running? the p05 from the cx or the p06 from the b7?</TD></TR></TABLE>
p05 from the CX. how would I check the cam timing?
DA6_toojy
10-12-2005 06:30 PM
STEV3-O
07-24-2005 09:02 PM
