steps in removing radiator
Re: steps in removing radiator (EnKidu)
Drain it first there is a plug that you can unscrew with your finger at the bottom then take of the two hoses and take off that brace on the top then lift up. It just sits in two holes at the bottom. And incase it isnt obvious move your fan and the rubber pieces on the bottom over to your new one if your replacing it.
1 Post
Re: steps in removing radiator (95excoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupe »</TD></TR><TR><TD CLASS="quote">Drain it first there is a plug that you can unscrew with your finger at the bottom then take of the two hoses and take off that brace on the top then lift up. It just sits in two holes at the bottom. And incase it isnt obvious move your fan and the rubber pieces on the bottom over to your new one if your replacing it.</TD></TR></TABLE>
That's it other than disconnecting the electric hookup to the fan...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">That's it other than disconnecting the electric hookup to the fan...</TD></TR></TABLE>
that is all unless your car is an automatic. then there are 2 transaxle lines that run to the bottom of the radiator.
