eg auto to manual conversion q's
I would like to start off by saying that i know the search ****'s will be all over this, but i have been searching for 20 mins and i need to get definate answers quick. I need a quick list of the unexpected things, like I have emassed a complete ls swap for this civic, And all the mounts from a 96 integra. But are any of the mounts not going to line up because the auto engine bay? I have the slave cylinder and the lines to the clutch master cylinder, I only have a clutch pedal as of now, but can get a brake pedal if needed? Any guidance would be helpful.
Re: eg auto to manual conversion q's (mattssi)
oh, and the ecu and wiring harness for the motor are all squared away. And i am going to wire up the backup sensor correctly, any thing else that i am missing?
Guest
Posts: n/a
you're going to need the trans mount for this conversion, hasport should have the auto to manual mount, you're going to need the gas, brake pedal assembly and if i remember correctly drilling two holes in for the linkage to bolt up to other than that you sound like you're good to go. Good luck
I'm really 2slow
Re: eg auto to manual conversion q's (honda eg9)
5 speed pedals,linkage,5 speed starter,tranny,clutch,master cylinder,auto-manual tranny mount. Maybe a few more things I left out
