denji projectors. only high beams work?
just as the topic says.
all of the fuses are in tact. i looked around a few places for replacement relays, but they seem damn near impossible to find. the ground and power wire to the LB are both connected. unless it's a short somewhere in the harness i'm out of ideas
anyone have a similar problem?
Re: (TheIntegraGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheIntegraGuy »</TD></TR><TR><TD CLASS="quote">W/ Denji projectors, it's usually the ground that is bad. The base of the bulb is ground so make sure it's making contact w/ the base. </TD></TR></TABLE>
that is exactly right, same thing happened to me, i ended up soldering a wire on it to ground it
Re: denji projectors. only high beams work? (HyBriDcxR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">Did you try puting the stock ones back in and seeing if both hi and low work like that?</TD></TR></TABLE>
if you mean put the stock headlights back in, then yes my high and low beams work correctly. it's only with the projectors that i have a problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">
that is exactly right, same thing happened to me, i ended up soldering a wire on it to ground it</TD></TR></TABLE>
you soldered in an additional ground? where at?
Re: denji projectors. only high beams work? (g4hatchie)
the bulb was making contact and everything with the plate but it the plate didnt seem to be grounded correctly so i soldered a wire to it, the bolted it to the frame of the car out the back of the rubber thing, i then sealed it with this liquid sealant stuff
UrbanLungs
Honda Civic (2001 - 2005)
06-05-2017 08:36 AM
standerby
10-29-2016 03:31 AM
mrbassman001
01-07-2011 10:22 AM
eghatchin
16
04-25-2008 04:46 PM
