code 71,72,73, and 74?
i have a 99 ex and i keep on gettig these codes. they are for misfiring in the cylinders. i just adjusted my timing and it went away but then it came back, what could be causing it? could my timing belt be going?
Re: code 71,72,73, and 74? (Andres-eh2)
i haven't messed with the plug wires anytime recently. maybe i'll try new plugs before i go changing the timing belt.
Re: code 71,72,73, and 74? (EE_Chris)
it had a t-25 but i sold that kit and pieced together a kit with a t3. not the bluebox but i am running a Vafc hack.
Re: code 71,72,73, and 74? (jeffsciv23)
What is your base timing set to? Did you verify it with a timing light?
Did you run the Hack on the old T25 setup? Did you have the same misfire problems?
CivicSmith
42
07-08-2014 12:54 PM
foreverjenn
09-28-2002 09:06 AM
