ARE AIR/FUEL RATIO GAUGES REALY ACCURATE?
I installed one but i do think im getting the right reading and im not going to lean it out just based on this gauge. The gauge reads 2-3 greens lights when idol, then 3-4 greens when wop. Is this right or is my o2 sensor done??? The guage dosnt pulse at all like i hear it should do. I go instructions but jsut wanted to know what you guys think?
thanks
jeff
thanks
jeff
Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (BeavisB16)
It is using your narrowband 02. That means it only tells you if it is rich or lean. They are nothing to try to tune with.
Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (turbogixxer)
yea ... there jus another flashing LED .... IMO... unless you have a what i thought was called a "Wideband O2" meter ... for acurate tuning...
Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (hondainspired)
with your stock o2 sensor, it might as well be a light bulb. because thats all it reads, on or off. it only reads rich, or not rich. there is no inbetween..
Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (vsm98civic)
ha....mine stays in the green when i'm driving and when i start to slow down to come to a complete stop, it goes to the red section. don't go by what this type of guage reads.
Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote">ha....mine stays in the green when i'm driving and when i start to slow down to come to a complete stop, it goes to the red section. don't go by what this type of guage reads. </TD></TR></TABLE>
its suppose to do that because you let off the gas....
Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (PRcivicHB)
OK mine duz the same thing. So basicaly go buy the aem $1,000 egt? lol
thanks.
Anyone need a used Air/Fuel gauge?
lol
jeff
thanks.
lol
jeff
Re: (B16Drag)
first make sure you have your purple wire from the guage hooked up to the right wire off the O2 sensor. it should be the white wire or signal high wire. i don't know what your car has OBD 1 or OBD 2 but it should be hooked up on the first O2 sensor that the exhuast gasses will hit first in this case it should be on the header.
Re: (00supercivic)
Without a wideband, you may be able to watch what is happening in the small area that your stock 02 sensor reads (0-1v) but a wideband reads 5 times that (0-5v).
Re: (hondainspired)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondainspired »</TD></TR><TR><TD CLASS="quote">but then without decent mods and some dyno tyme.. wideband still isn't really even needed</TD></TR></TABLE>
Why is that? explain.
