Catch Oil Can
Old 11-13-2004, 12:11 PM
Dropped90Integra's Avatar
Default Catch Oil Can
Got a brand new catch can that I bought for my old DSM I had. Want to put it to use now but I don't know how it would go on the Hondas. On DSM's it had 2 valves on the valve cover , hondas I believe don't so how would it work on it, I have a 95 Coupe 1.5. Thanks for advice, lookin to do this, this weekend
Old 11-13-2004, 08:28 PM
Default Re: Catch Oil Can (Slammed95Coupe)
Bump... anyone?
Old 11-13-2004, 08:31 PM
Street Ghost's Avatar
First of all, why do you need an oil catch can on your 1.5l? Are you turbo'ed? Or is the motor pretty much stock?
Old 11-13-2004, 08:33 PM
Default Re: Catch Oil Can (_Project EJOne)
Stock, but I'm swappin in the B18 soon but pretty much just wanted the heads up of how it would go on the 1.5 since the b18 would be close to if not the same way
Old 11-13-2004, 08:38 PM
92 CIVIC HATCH VX's Avatar
yes a catch cans a catch can you might have to make a custom braket but yes it serves the same purpose.
we sell SARD racing catch can's for about 80 dollars.
Old 11-13-2004, 08:40 PM
Default Re: Catch Oil Can (92 CIVIC HATCH VX)
where would the hoses go on the motor for the catch can if what I'm tryin to figure out on the honda motors.... i'm used to the DSM stuff, gotta get off that kick
Old 11-13-2004, 08:41 PM
there a air release pipe that comes out of your valve cover and it runs to you intake
the catch can sets in the between that.
Old 11-13-2004, 08:44 PM
So only one hose gets connected and it goes where the little line runs to the intake, instead of to the intake pipe, goes to the catch can, so the other end on the can gets capped?
Old 11-13-2004, 08:46 PM
no run it to you intake the can just cathes the blow by
Old 11-13-2004, 08:47 PM
SyDuck's Avatar
nah..
your engine has a pipe going from the valve cover to the intake manifold. disconnect that. reconnect pipes, running both of them to each of the holes in the catch can
Old 11-13-2004, 08:53 PM
No, your catch can should have two fittings on it. So one hose will go from the nipple on the intake pipe to the catch can. Then another hose will go from the valve cover nipple to the other fitting on the catch can.
Old 11-13-2004, 08:58 PM
So the hose that runs from the valve cover to the intake pipe, I put the catch can right in the middle of it?
Old 11-13-2004, 09:04 PM
yes
TravisBiggie
07-03-2012 10:48 AM
soon2bdropped
12-16-2010 07:40 PM
Flux
05-09-2004 10:33 AM
GTEater
11-08-2001 07:49 AM
GruvyTune
10-22-2001 01:29 PM
Quick Reply: Catch Oil Can
