Goodridge brake lines and bolts question.
I just bought a set of Goodridge brake lines and respective hardware, but it didn't come with instructions. I started the installation only to find out that I could not torque the bolts that came with the set to the settings specified on the manual (1st bolt broke in half). I ended up using the same bolts that were there before. Has anyone encountered this problem before?
Re: Goodridge brake lines and bolts question. (JoseCuervo)
Yep, the goodridge bolts are weak and break when overtorqued.
You're fine using the stock ones, several people including myself did.
Re: Goodridge brake lines and bolts question. (Echo7847)
Yep, I had one break on mine as well -- just use your original bolt. I am believed that they are just plastic banjo bolts.
Echo7847,
Thanks for the reply. I just wanted to make sure that I was going to be OK by using the old bolts. I didn't think that I was going to have any problems. Better safe than sorry!
Re: Goodridge brake lines and bolts question. (Mario BA4)
Mario BA4,
As soon as the 1st one broke I didn't even think about using the rest of them. One thing I did change was the washers. They are pretty weak. Thanks for the reply!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoseCuervo »</TD></TR><TR><TD CLASS="quote">Mario BA4,
As soon as the 1st one broke I didn't even think about using the rest of them. One thing I did change was the washers. They are pretty weak. Thanks for the reply!</TD></TR></TABLE>
Yea no problem -- ironically, only the last bolt I put on broke... since the others were fine, I just left them.
Deano_D aka "Brick Top"
14
02-21-2005 12:37 PM
