Blinkers no worky
Blinkers no worky
Yeah my blinkers dont work anymore but my hazards work i think i blew a fuse but i dont know where the fuse for my blinkers is located help please TY
Electrician
Check your fuse panel under your dash. The panel you pull off has a diagram of which is which. If it's not there, there's another fuse box under your hood in front of the battery that also has the diagram.
Re: (Dimi)
Yeah i checked both and my dash box has no diagram and my hood box dose but i dont know what one to fool around with. So like what fuse would cause my blinkers not to work but my hazards to work. Thanks for help
Re: (Ricta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricta »</TD></TR><TR><TD CLASS="quote">Yeah i checked both and my dash box has no diagram and my hood box dose but i dont know what one to fool around with. So like what fuse would cause my blinkers not to work but my hazards to work. Thanks for help </TD></TR></TABLE>
check the lights are not burnt out.
Dont fool around with the fuses, go to Kragen and get a buss fuse tester and check them all.
If its not the fuse, replace the relay. (Under dash)
Maybe the switch 2.
Use hand signals to avoid loss of limb in the meantime.
Maybe the switch 2.
its one of the fuses under the dash - Im positive
https://honda-tech.com/zerothread?id=910218
https://honda-tech.com/zerothread?id=730506
