HELP b18 not running right
I have 93 civic hb and i swapped a b18a and am runnign p75 ecu... it was running right for about a week now it seems as if the 4th cylinder is not firing, i pull the spark plug and its dripping with gas. and i pulled the plug and checked for a spark and did not see one.
Re: HELP b18 not running right (civichatch6989)
switch spark plug with known good (it's out already right), check wire for spark and proper seating & impedance if possible, check cap for bent contact.
Re: HELP b18 not running right (miahmouse)
just got brand new plugs and wires still not working right.. i think im going to try a new distributor
cap is fine, found out that i am getting a spark, but the cylinder is just not firing. i started the engine pulled each plug one at a time and each one when i pulled it the engines idle when down, when i got to the 4th plug when i pulled it the idle stayed the same, it is getting fuel just not being burnt. I think maybe its a burnt valve, so i just took it to my local shop to be put on the diagnostic machine to know for sure
shop called and said that my CAM timing was off and also possible injector and/or intake leak; cylinder number 4... so i decided to just let them fix it for like $200, havent got it back yet
got it back today they set the cam timing for $130 and they said i needed a new injector on cylinder number 4 so i took the car home and swapped it out with one from my old motor, started it up and runs like a champ, caught gears up to 3rd on stock clutch
