Noise coming from front end!
I am getting a noise from the front of my 99 hatch. It is coming from the passenger side front. I recently was cut off and hit a wall hard enough to make my driver side upper motor mount explode and brake my front rim, brake rotor, and caliper. So I bought some 94 integra ls front brakes for the front end. I had the wheel bearings replaced. Now as I am driving the car and when I slow down under 15mph I feel something in the brake pedal and hear a noise that is like something knocking. The brake pedal vibrates a little. The car does not vibrate or pull to the side in any way. What could the noise be coming from? Bad ball joints,axles? Another thing when I hit the wall my rear rim was messed up too. Now the rear wheel is cambered out I already replaced the lower control arm and the rim and that did not fix it. What could that be, bent trailing arm?
Thanks in advance.
Thanks in advance.
JZiggy
Honda CR-V & Element
03-03-2018 07:58 PM
redm3turbo
06-14-2011 05:04 AM
