04 cluster in 00
Re: 04 cluster in 00 (sheepy_peepy)
not sure buy the helms manual
on a side note I will be installing a RSX-S cluster in my '00 hatch. Everything will be custom. I had to purchase the RSX-S engine harness, interior harness, & under the dash fuse box (w/built in multiplexor) as well as duplicate '00 civic harnesses which are going to be made into one custom engine & interior harness - THE ONLY WAY this is going to work is with a the k20a swap going in.
RSX-S have a multiplexor & single digital communication line which sends multiple signals through the same line. This complicates things greatly - if '04 civics have a multiplexor you are basically screwed
EDIT after seeing the above posts your screwed - its got a multiplexor / digital communication line. but if you ever get a k-series swap you COULD make it work for a lot of extra money
PS you may ask why I am going to do this...because I am stupid & opened up a can of worms before realizing how costly & troublesome this part of my project is
Modified by adirondackR at 2:47 PM 11/24/2004
Re: 04 cluster in 00 (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">not sure buy the helms manual
on a side note I will be installing a RSX-S cluster in my '00 hatch. Everything will be custom. I had to purchase the engine harness, interior harness, & under the dash fuse box (w/built in multiplexor) as well as duplicate '00 civic harnesses which are going to be made into one custom engine & interior harness - THE ONLY WAY this is going to work is with a the k20a swap going in.
PS you may ask why I am going to do this...because I am stupid & opened up a can of worms before realizing how costly & troublesome this part of my project is </TD></TR></TABLE>
Yep, that's why S2000 clusters never fully work in other cars.
prelude2.2
03-03-2012 01:35 PM
jdmek910
05-04-2005 11:05 AM
