doing a y8 tranny swap have some questions?
well i currently have a z6 and im going to get a y8 trannny when buying a clutch and fly wheel should i buy it for a y8 tranny or z6 tranny or does it matter ????
Don't do it.... J/K I've been having problems with my y8 tranny. The shift forks are steel but the way they connect to the shaft is a joke.... I am on my second set of shift forks and 3rd tranny.... Seems like the 1-2 shift forks on the y8 trannies are prone to bending.... The z6Aluminum forks are much stronger....
Sorry to rant but as Bauley stated both clutche, pressure plate and flywheels are all interchangeable...
Location: hittin corners so hard you can taste my rims..
Re: (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst »</TD></TR><TR><TD CLASS="quote">Seems like the 1-2 shift forks on the y8 trannies are prone to bending.... The z6Aluminum forks are much stronger....</TD></TR></TABLE>
bending the 1-2 fork may be true.. but no way how can be... the EG forks are stronger than the EK's.. aluminum and steel.. come on.
the EK tranny is the way to go. EG's
What is the purpose of changing from the Z6 to the Y8 tranny? the gearing is the same. It's like having a Z6 engine and swapping a Y8 head onto it. Waste of time and money for no tangible benefits.
Risky Business
Re: (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger »</TD></TR><TR><TD CLASS="quote">What is the purpose of changing from the Z6 to the Y8 tranny? the gearing is the same. It's like having a Z6 engine and swapping a Y8 head onto it. Waste of time and money for no tangible benefits.</TD></TR></TABLE>
Because Mista Bone says that the Y8's steel shift forks are stronger and more durable than the Z6's aluminum ones. And since everyone in this forum hangs from his ******* (including myself), everyone believe that the Y8 is worth swapping to from the Z6.
Re: (klungemonger)
Dude read...the shift forks are stronger.
Re: (95excoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupe »</TD></TR><TR><TD CLASS="quote">
Dude read...the shift forks are stronger. </TD></TR></TABLE>
Dude, I did read...can anyone prove how much stronger they are? For your basic daily driven D16 is it going to make a significant difference in the reliability of the car? I seriously doubt it. If you bang the Z6 tranny hard enough to snap the forks, at some point you're bound to damage your Y8 tranny too.
To me it's like getting forged 9.5:1 c/r pistons for your all-motor daily driver. Definitely stronger than stock...but do you really need them?
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Because Mista Bone says that the Y8's steel shift forks are stronger and more durable than the Z6's aluminum ones. And since everyone in this forum hangs from his ******* (including myself), everyone believe that the Y8 is worth swapping to from the Z6.</TD></TR></TABLE>
speed shift your Z6, and then let me know how long your shift forks last... syncro's arn't the issue... they're the same.
I don't argue with the Bone either, he is the guru. Speed shift any D-tranny and see whether the forks or the synchros are first to go. I got a Y8 tranny, forks might be alright but syncros are on the way out since I first put it in.
Even Mista Bone will tell you, you can only shift the tranny so quick or it's just going to go bad on you one way or another.
Re: doing a y8 tranny swap have some questions? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Doesn't matter...all 92-00 civic clutches (With the exception of Del Sol VTEC and EM1 Si) are the same</TD></TR></TABLE>
Not true. My del sol S has a clutch with 10 less MM all the way around. Did not work with a ACT clutch that was sold to me so I had to get an ex flywheel. Also dependent upon what tranny you get from a y8 and the year, the mount may be different, and some of the sensors may look different, and some of the placement of things is moved around a little bit.
Hope this helps out some.
Risky Business
Re: doing a y8 tranny swap have some questions? (Mwsol)
http://www.slhondaparts.com
Del Sol S Pressure Plate: 22300-P10-000
Del Sol S Clutch Disc: 22200-P10-000
Del Sol S Flywheel: 22100-PEL-005
Del Sol Si Pressure Plate: 22300-PEL-005 OR 22300-PEL-015 OR 22300-P29-010
Del Sol Si Clutch Disc: 22200-P29-040
Del Sol Si Flywheel: 22100-PEL-005
Flywheel and Pressure plates are the same between DX's and EX's, it is the discs that are different (have different part #'s at least)
<U>However, for 1996-2000 Models-</U>
DX Clutch Disc: 22200-P2E-013
EX Clutch Disc: 22200-P2E-013
So who knows. I'm 99.999999 % sure of my previous statement.
slikz714
10
06-16-2007 04:59 PM
95civicSirCoupe
06-04-2004 05:27 AM
