Will HX WHEELS clear 92-95 SI Brakes?
Re: (skt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skt »</TD></TR><TR><TD CLASS="quote">It did on mine, not sure about ABS versions tho?</TD></TR></TABLE>
i dnt know how you managed that. With out modifying the caliper.
be professional
Re: Will HX WHEELS clear 92-95 SI Brakes? (SuperVince)
As long as your EH3 Si doesn't have ABS, HX wheels will fit on it with no modifications.
If you have a '94 Si with ABS, then you will need to either grind down the caliper bracket or use a spacer.
Re: Will HX WHEELS clear 92-95 SI Brakes? (Targa250R)
I have a 95 civic coupe EX, so if the 92-95 SI brakes are the same, they will not fit without spacers. I am guessing the brakes are different though since a few people posted they fit HX wheels on there SI without spacers. I am using H&R 5mm spacers and I don't have ABS.
be professional
Re: Will HX WHEELS clear 92-95 SI Brakes? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">I have a 95 civic coupe EX, so if the 92-95 SI brakes are the same, they will not fit without spacers. I am guessing the brakes are different though since a few people posted they fit HX wheels on there SI without spacers. I am using H&R 5mm spacers and I don't have ABS.</TD></TR></TABLE>
AFAIK, all EXes had 10.3" front brakes, so you will probably need to shave down the caliper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
AFAIK, all EXes had 10.3" front brakes, so you will probably need to shave down the caliper.</TD></TR></TABLE>
nope...just the caliper
1kleenef
02-12-2009 06:22 PM
alexb18c1
07-10-2008 04:04 AM
Dangydang
20
04-22-2003 02:10 PM
