Small leak on transmission, need help.
hey, I have just noticed a small leak on my transmission. The engine is a '97 B18C1. I have located the leak in the picture and just want to know what this part is and how it can be fixed? thanks
Risky Business
Re: Small leak on transmission, need help. (CivHizzle)
Clutch slave cylinder appears to be leaking brake fluid. I'd get a new one and re-bleed your system.
Unbolt the slave cylinder first, and make sure that it is leaking brake fluid and not oil...if its oil, your transmission bell housing is cracked or your rear main/input shaft seals are leaking.
Sorry to give you bad news!
Re: Small leak on transmission, need help. (BauleyCivic)
it does appear to be leaking the brake fluid. I just checked the level of the brake fluid and its getting low and i replaced it not that long ago. thanks
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivHizzle »</TD></TR><TR><TD CLASS="quote">it does appear to be leaking the brake fluid. I just checked the level of the brake fluid and its getting low and i replaced it not that long ago. thanks </TD></TR></TABLE>
Then just replace your slave cylinder and you'll be all set
