Holy wierd overheating problem
So I just boosted my 92 CX with a 98 B18. My car has an overheating problem. When driving the car the temp reaches in between 192-194. When you stop (with heater on) it will start to drop back down. I changed the thermo, bled the system. I am going to change the radiator tomorrow (hopefully). Does anyone have any other suggestions i should look for. It seems also that once i get on the freeway it jumps up quicker. ANY HELP PLEASE!!!!
Re: Holy wierd overheating problem (teknikEG6)
Double sealed thermostat?
boosted? (swap? turbo??)
98 b18...vtec, non vtec?
if you didn't replace the radiator along with your swap, you should probably buy the corresponding OEM replacement, for the motor that is.
could be your radiator... as soon as i went from 1.5 8 valve to 1.6 16 valve it started getting hot alot... i replaced everything form hoses to waterpump to thermostat to thermoswitches.. nothing.. replaced the single row cx radiator with an aluminum autozone 2 row... its good to go
billythepunk21587
03-02-2008 01:15 PM
crashtest Sonny
34
01-26-2007 10:53 AM
