Headunit question *posted in audio, but that section is dead*
Re: Headunit question *posted in audio, but that section is dead* ({PBA}Threat)
Just run longer wires to your headunit?
Are you just trying to put your headunit by the shifter?
Re: Headunit question *posted in audio, but that section is dead* (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">Just run longer wires to your headunit?
Are you just trying to put your headunit by the shifter?</TD></TR></TABLE>
I want it in that pocket behind the cupholders... if you know what I mean.
I've heard of people doing it on the civics, but I don't see any How-To's for it
Re: (egb18c5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb18c5 »</TD></TR><TR><TD CLASS="quote">here's a diy on it, hope this helps
http://www.clubcivic.com/board...58073</TD></TR></TABLE>
do I have to be a member to view the pics? or are they just down?
EDIT: nevermind, I registered and now it works.... thanks a lot guys!
Re: ({PBA}Threat)
It is REALLY straighforward. All you need is a screwdriver and a 2nd grade education and you will be able to do it j/k. Just try it. It is really easy. I had never really heard of anyone doing it when I had done mine, and I just did it. Took me probably 20-30 minutes MAX. Good luck.
-Shane
-Shane
Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">It is REALLY straighforward. All you need is a screwdriver and a 2nd grade education and you will be able to do it j/k. Just try it. It is really easy. I had never really heard of anyone doing it when I had done mine, and I just did it. Took me probably 20-30 minutes MAX. Good luck.
-Shane</TD></TR></TABLE>
did you use the 96-98 cupholders or just hack away the 99-00?
it looks like you need the 96-98 cup holders, i never tried it before but from looking at mine, it seems like the 99-00 cup holders wouldn't work as good as the 96-98's
Loco Honkey
Welding / Fabrication
06-12-2006 05:38 AM
