mini me: b7 with y8 head. do i use z6 or y8 timing belt?
Old 07-19-2005, 09:01 PM
mike93eh
Guest
Posts: n/a
Default mini me: b7 with y8 head. do i use z6 or y8 timing belt?
im outting a y8 head on a d15b7 block and was wondering if i should use a z6 or y8 timing belt. i know if you use a z6 head on it then you need the z6 timing belt. i noticed that z6 and y8 belts have different part numbers so whats different and what do i use?
Old 07-19-2005, 10:02 PM
mike93eh
Guest
Posts: n/a
ack i need to know quick. z6 or y8 belt with y8 head??
Old 07-19-2005, 10:16 PM
Ignitecivic's Avatar
Default Re: (mike93eh)
Y8 belt
Old 07-20-2005, 02:43 PM
mike93eh
Guest
Posts: n/a
Default Re: (Ignitecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic &raquo;</TD></TR><TR><TD CLASS="quote">Y8 belt</TD></TR></TABLE>
really? i heard from other people they used a z6. whats the difference in the belts and why would they be different?
Old 07-20-2005, 04:16 PM
im not sure about the difference between the two but im pretty sure u use watever belt for watever head ur gonna use. z6 head z6 belt, y8 head y8 belt, d15b jdm block with z6 head use the vx belt but some say i tried the z6 belt and it works.
good luck. if im not clear on what i said, some of the sohc soldiers out there will help u out.
Old 07-20-2005, 04:23 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic &raquo;</TD></TR><TR><TD CLASS="quote">im not sure about the difference between the two but im pretty sure u use watever belt for watever head ur gonna use. z6 head z6 belt, y8 head y8 belt, d15b jdm block with z6 head use the vx belt but some say i tried the z6 belt and it works.
good luck. if im not clear on what i said, some of the sohc soldiers out there will help u out. </TD></TR></TABLE>
i know thats the case with the headgaskets but didnt know about the timing belt.
dohc4life
08-14-2010 08:50 AM
blinger
07-22-2007 04:33 PM
DA91TEGGY
04-19-2005 03:55 PM
4drEF
05-18-2004 02:14 PM
Quick Reply: mini me: b7 with y8 head. do i use z6 or y8 timing belt?
