has anyone switched to integra front calipers?
i have a del sol vtec, which basically has the same brake setup as the integra. the only difference that i know of is the integra has larger front calipers / larger brake pads, on the same size rotor. has anyone with a del sol vtec or civic with abs done this and noticed a difference? thanks.
Re: has anyone switched to integra front calipers? (bootlegtrader)
I have, and just posted another thread asking for information. I'm not sure if a civic EG is the same as the del sol, but my problems are that the inside of the tire rubs into the inside fender when turned all the way to the right and left, it has a negative camber (top of the wheel is tilted inward), and the wheels are in a 'toe in" alignment (the front of the tires are turned towards one another (like a pigeon toe). I was able to fix the toe problem, but asking people if what the recomended fix for the other two are.
mugenNR10
07-14-2011 12:10 PM
eg2phosizzle
03-18-2006 06:09 PM
phantom_sol
10-07-2003 01:56 PM
