vtec not engaging in my d16z6. No codes, need help.
I have owned my 95 vx with d16z6 swap for a few months now and I noticed it would never engage vtec. So today I swapped out vtec selinoids. no vtec! I have no codes, plenty of oil. need suggestions what to check next.
thanks
thanks
Re: vtec not engaging in my d16z6. No codes, need help. (dpine)
Since your car is not a civic si or civic ex you will need to get a civic ex harness or a vtec contoller to make vtec work!
Re: vtec not engaging in my d16z6. No codes, need help. (turbo__man)
VX's came with vtec so he doesnt need to wire it
just curious how do you know vtec isnt engaging?? and if you have no cel's there shouldnt be a problem, are you sure the CEL works?
you are running a p28 right?
you need your stock vx 5 wire o2 with out it you wiring is no good us a stock 5 wire on the swap tahts what i did
Re: vtec not engaging in my d16z6. No codes, need help. (sivicb18c5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sivicb18c5 »</TD></TR><TR><TD CLASS="quote">you need your stock vx 5 wire o2 with out it you wiring is no good us a stock 5 wire on the swap tahts what i did</TD></TR></TABLE>
not if he is running a p28, then he needs 4 wire
