power door lock problem - manual locking doesn't work
-On my passenger rear door the power locks work, but the manual doesn't.
-I've had the door apart and there's nothing catching the rod or anything of that sort. -The power locks work fine and the manual latch moves lock/unlock as it should, but one cannot move the manual latch itself... It seems to be "locked" or "frozen" into whatever state the door is in (either locked or unlocked).
I replaced the power locking mechanism to no avail... and when that power mechanism was removed the latch assembly works perfectly.
Any Ideas??
TIA
Any Ideas??
TIA
Re: power door lock problem - manual locking doesn't work (zenon)
i have the same problm on the same door. except mine still unlocks and locks manualy
ive checked all the plugs and such but havent replaced my locking mechanism. so far nothing i have done has helped.
I had a similar problem on my car last summer, only with mine neither worked very well just the key. I ended up taking out the lock and latch from my door and cleaning it and re greasing all the pivot points and its worked great ever since.
I have tested it according to the honda repair manual and it is supposedly functioning properly.... it locks/unlocks as it should... except it is "locked" into position, you can't use the latch @ all.
http://cnideria.multiply.com/photos/photo/5/1.gif
Nickboxer7
04-18-2008 08:32 PM
jeffsciv23
12-20-2005 10:30 PM
projektvtec
10-02-2005 09:42 AM
