Front disk Integra swap Issues
I swapped out my EG front disk brakes with a 92-95 Integra front disk brake (with the knuckle), thinking that it will fit right in just like the rear, without any issues. Well I learned the hard way that the toe adjustment is thrown off big time (toe in like a motha), the camber adjustment went significantly negative (the top of the wheel is in, you can tell it from a 45 angle and from the front), and my tires now rub in the inside of the wheel well when I turn all the way to the right/left.
I was able to fix the toe problem, but I know that there is no camber adjustment on Honda's, which brings up my question. How can I correct this? Can I just get an upper suspension arm from an Integra, or do I have to purchase an adjustable upper arm? If you have any experience or knowledge on how to do this, please don't hesitate to respond. Thanks.
Re: Front disk Integra swap Issues (2point3h22lude)
Please someone put some input. It would be cheaper to get a used integra upper arm, than an adjustable one. Anybody?
Re: Front disk Integra swap Issues (SkoundrelUSA)
Most people swap over the entire thing, so try to go look for the integra upper arm, it shouldn't matter though. hehe just a thought, did U put it on opposite sides?
Re: Front disk Integra swap Issues (DjGuamstyles)
Thanks for your input, yeah I didn't know any better. I should have bought it with the upper arm, lesson learned for those who are planning to make the swap. I believed the guy that sold me the brakes when he said that it was a complete swap. I was wondering why it was so cheap ($65 shipped for the pair). I'm sure installed it on the correct side, I don't think it will fit the other way.
Slammd Sol
07-30-2007 12:07 PM
UrbanEh
02-01-2007 03:35 AM
