install air fuel ratio gauge
Old 09-12-2005, 08:44 AM
JspekSI24's Avatar
Default install air fuel ratio gauge
im trying to install my air fuel ratio gauge, and im wondering where do i tap the purple wire into?? i have a 00 civic si obd2
Old 09-12-2005, 08:47 AM
Bounty - € 8,000,000
.Radical_Edward.'s Avatar
Default Re: install air fuel ratio gauge (JspekSI24)
You might as well not even tap it at all. You will get a better readout that way.
but really though there are teo ways you can do it. One is to look for the o2 sensor wire going to the ecu, or to the O2 itself. I don't know much past that.
Old 09-12-2005, 08:49 AM
G2 Speed's Avatar
Default Re: install air fuel ratio gauge (Radical_Edward)
search
Old 09-12-2005, 08:50 AM
JspekSI24's Avatar
what color is the 02 sensor wire into the ECU
Old 09-12-2005, 08:51 AM
G2 Speed's Avatar
search
Old 09-12-2005, 09:08 AM
bradykiller's Avatar
Default Re: install air fuel ratio gauge (G2 Speed)
Here's an ECU pinout chart for ya.
http://www.ff-squad.com/technet/wiring.obd2b.htm
Old 09-12-2005, 09:15 AM
JspekSI24's Avatar
Default Re: install air fuel ratio gauge (bradykiller)
appreciate that. it helps alot.
Old 09-12-2005, 09:19 AM
EJ4door's Avatar
I just finish putting one on my friend's car. What i did was put a T tap on the Green wire on the o2.
Old 09-12-2005, 09:21 AM
cibola's Avatar
G2 Speed dont be an a**hole. You guys with the search BS is BS!
We are here to try and help each other with our vehicles so if you cant help the guy, move on or type in something useful.
I am getting so pissed off that almost every post has "Search you idiot" put in by some d***head that only wants to have a additional post tick under his name.
Old 09-12-2005, 10:29 AM
IHateJDM's Avatar
Default Re: install air fuel ratio gauge (cibola)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cibola &raquo;</TD></TR><TR><TD CLASS="quote">I am getting so pissed off that almost every post has "Search you idiot" put in by some d***head that only wants to have a additional post tick under his name.</TD></TR></TABLE>
the same can be said of someone who posts without searching. there are times when I agree with you, but this particular question comes up multiple times a week. If people didn't tell noobs to search on the easy stuff that's been covered a thousand times, all this forum would be is repeat questions, and topics on newer subjects would be forced to other pages where they wouldn't be seen. Besides, if he had searched, he would have found out that A/F guages dont really do anything without a wideband anyways.
Old 09-12-2005, 11:49 AM
JspekSI24's Avatar
thanx CIBOLA
krysted9354
01-24-2009 06:23 PM
Crab Man
05-18-2007 06:43 PM
StrtRacerB16A2
08-27-2006 10:50 AM
riddickone
11-26-2003 10:24 AM
HOND PWR
02-05-2003 06:12 PM
Quick Reply: install air fuel ratio gauge
