Uninstalling V-AFC
Old 09-11-2005, 12:49 PM
Bee18Hatch's Avatar
Default Uninstalling V-AFC
I am wanting to remove and sell my V-AFC...It is installed into the plug & play harness that snaps in & out....and I going to have to rewire the harness wires to the ecu or just unplug?? Help appreciated!
Old 09-11-2005, 12:52 PM
REAL TIME's Avatar
Default Re: Uninstalling V-AFC (Bee18Hatch)
if it's plug and play then it should go back to stock the same way. I have pnp on my vafc2
Old 09-11-2005, 01:04 PM
Bee18Hatch's Avatar
Default Re: Uninstalling V-AFC (Spoon_Fed_EM1)
You mean by just unpluggin it right?
Old 09-11-2005, 05:14 PM
Bee18Hatch's Avatar
bump
Old 09-11-2005, 05:34 PM
HondaFanatic708's Avatar
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bee18Hatch &raquo;</TD></TR><TR><TD CLASS="quote">You mean by just unpluggin it right?</TD></TR></TABLE>The VAFC comes with the plug and play wiring. In order to uninstall you would have to trace those back to where the ECU wiring was cut. That plug and play wiring should be sold with the VAFC. But I know you will have to re-make a few connections that the VAFC functions off of. Good luck and have fun..
Old 09-11-2005, 09:03 PM
Bee18Hatch's Avatar
Default Re: Uninstalling V-AFC (HondaFanatic708)
Thanks....You know if there is a step by step on HT? Searched but couldnt find
Old 09-11-2005, 09:10 PM
Luserkid's Avatar
Just go to where your ecu is and youll see the extra wires attached. Undo all the wiring from the harness. Note though, that there are 2 wires that will be cut you will need to reattch them. I sugguest soldering.
Also disconnect your battery before you even start this.
Old 09-11-2005, 09:22 PM
dmxsoulja3's Avatar
Default Re: Uninstalling V-AFC (Luserkid)
mine had been taken out before in my old Lude and I got water on my floorboard and had to pull the carpet and ECU and when I put the ECU back in the car ran like complete ****, during the process of removal I had moved the harnesses around and pulled the tape and stuff off where it used to be connected not knowing which one was causing the issue I ended up cutting every wire that had ever been touched soldering a new piece of wire in, then soldering it back to the wire, shrinkwrapped and taped, and once I was all done, it ran like a dream...if you do a shotty job you are risking some serious issues..like the other guy said one wire is spliced twice that one will DEF have to be extended...take your time you will thank yourself later.
Old 09-11-2005, 11:23 PM
Blk00EJ8's Avatar
Just to elaborate on what was said, I'd suggest getting the instructions for wiring the VAFC for your car/ecu and working backwards from there. Simply unplugging the VAFC and calling it a day would probably fall under the warning provided by apexi... "IMPROPER INSTALLATION MAY LEAD TO SERIOUS ENGINE DAMAGE," or something along those lines
Old 09-12-2005, 06:21 PM
Bee18Hatch's Avatar
Default Re: Uninstalling V-AFC (EKcivicEX)
So, should I have a professional do this? I really dont want "Improper Uninstalation Did Cause Serious Engine Damage."
Old 09-12-2005, 08:38 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bee18Hatch &raquo;</TD></TR><TR><TD CLASS="quote">So, should I have a professional do this? I really dont want "Improper Uninstalation Did Cause Serious Engine Damage." </TD></TR></TABLE>
No, you don't need a professional to do it. The warning is intimidating, but it's really not difficult to do at all. It's as easy as following a few wires and unplugging them from the VAFC harness, and plugging them back in together (or soldering if necessary, if the job was done half-assed). Plus the 2 or 3 wires that were cut originally and left dangling need to be soldered back together. Piece o' cake. Just get the install instructions and read it over, its straightforward.
Old 09-13-2005, 08:46 AM
Bee18Hatch's Avatar
Cool thanks
Old 09-13-2005, 08:53 AM
Redsun's Avatar
What car do you have? I made a simplified diagram when i installed my VAFC2. Send me an IM and i can email it to you.
Old 09-13-2005, 09:25 AM
chinkest_raver's Avatar
i thought v-afc sucks butt crack dont it?
Old 09-13-2005, 09:26 AM
D15Bbigred's Avatar
its an expensive light show, but hey works for some people
Old 09-13-2005, 09:45 AM
resol's Avatar
Default Re: Uninstalling V-AFC (Redsun)
redsun- can you send me that diagram also, been wanting to take it out, but dont know what to mess with, came with the car when i bought it, so it doesnt have a manual
Old 09-13-2005, 10:03 AM
Bee18Hatch's Avatar
Default Re: (EJ1D16Z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1D16Z6 &raquo;</TD></TR><TR><TD CLASS="quote">its an expensive light show, but hey works for some people</TD></TR></TABLE>
Yea, it really isnt worth the $$. I would rather be chipped. All the V-AFC does is b/s the ecu....I don't wanna **** him off ya know
Old 09-13-2005, 10:28 AM
resol's Avatar
Default Re: (Bee18Hatch)
yes really, and you could sell it and make 100-150 off of it
Old 09-13-2005, 01:27 PM
Bee18Hatch's Avatar
Default Re: (resol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by resol &raquo;</TD></TR><TR><TD CLASS="quote">yes really, and you could sell it and make 100-150 off of it</TD></TR></TABLE>
Exactly!!!
Old 09-13-2005, 02:05 PM
junior40er's Avatar
Nah if tuned properly it will worked great. I had mines tuned by XS Engineering and they tuned it on the dyno and when they where done my car perfomed better while giving me more mileage. Yes more mileage cause you can tune air/fuel with VAFC2
junior40er's Avatar
Default Re: (junior40er)
You know what I think? I just think you guys are baging on the unit cause it's too expensive for you budget. It is expensive but worth it if tuned right
Old 09-13-2005, 03:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote">You know what I think? I just think you guys are baging on the unit cause it's too expensive for you budget. It is expensive but worth it if tuned right </TD></TR></TABLE>I own one and I'm ditching it. No adjustment of ignition maps to match the tuning the VAFC does.. Going Chrome here.
Old 09-13-2005, 03:34 PM
junior40er's Avatar
Default Re: (HondaFanatic708)
I like your sig man
Old 09-13-2005, 03:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote">I like your sig man </TD></TR></TABLE>LOL yeah it's been catching peoples eye. True story though, funny part is the bitch wanted (and still does) to marry me. I couldn't keep a straight face. Don't try and pull your man away from his car ladies.
Old 09-14-2005, 09:01 AM
Redsun's Avatar
Please PM me your PM me your email if you want the diagram.
I gained 20whp after tuning with VAFC2. It does the job for fuelling but theres no point in messing with Vtec engagement point cos you can't tune ignition.
Chris N
03-06-2010 10:18 PM
Nagata-San74
Honda S2000
12-08-2007 07:03 PM
blkvtec
12-13-2004 04:04 PM
HYREV2NR
11-12-2003 08:44 AM
LSTEG96
11-06-2003 09:14 PM
Quick Reply: Uninstalling V-AFC
