EG corner lights
Re: EG corner lights (civicsareslow)
There is one screw holding it onto the headlight bracket. It is inbetween the headlight/corner and then u just turn the light for it to come out.
No exact science to that. Just get in there and unscrew everything until the origional pops out. I did it in about 15 for both my first time. The EK headlights are even easier to take out, but i got the EG ones out fine.
Get a screw driver, pop your hood, and then unscrew the obvious screws that are holding it in, take the bulb out of the hold corners and put them in the new and then place the corners where they are supposed to be and screw them in tight. Close you hood, put away the screw driver. Left is to loosen, right is to tighten.
Full write up.
First you have to put the car up on jacks/jack stands. And none of those bullshit 2 ton level jacks, we need full blown 10 ton cylinder jacks. After you have put the car up, take off all 4 wheels using your tire iron. After you've done that you want to go ahead and remove your back seat then pop the lights right in, after all of that work they should fall right into place.
nah man just givin ya a hard time, lets see some pictures though, i'm thinkin about doin some in my car.
bobby frm 3star
07-16-2006 11:56 PM
