misfiring, stalling and a bright cel whats the problem?
Old 09-12-2005, 08:35 AM
.Kevin.'s Avatar
Default misfiring, stalling and a bright cel whats the problem?
Yes i have searched looked at the misfiring problems and so on but now, i swear it just keeps getting worse and i don't know what other parts to replace.. I have a misfire in cyl. 1,2,3,4 and a cel for an 02 sensor that i knew about, and is being replaced.. but the misfires i don't know what to do, i did a cap and rotor, plugs wires, checked timing and adjusted the valves. I hate to replace the entire distributor for 150$ and that turn out to not be the problem.. are there any other small things that can cause this besides the last thing left the distributor? I do not know if this pertains to the misfiring but every so often when i go to start my car it bogs like hell in the morning under full throttle, so i let it sit for 2 hours and come home and take it out and its fine. I just don't understand this and what is wrong so please help and i have emissions date coming soon and they go off of the cel so i need these things cleared up! thanks
Old 09-12-2005, 08:52 AM
undertheradar's Avatar
Default Re: misfiring, stalling and a bright cel whats the problem? (Slow_CvC99)
When my primary O2 sensor went bad, it caused symptome similar to what your describing. Sputtering at idle and stalling. A bad o2 sensor will cause your car to run rich, and you gas mileage will suck ***.
Old 09-12-2005, 09:44 AM
EJ4door's Avatar
Are you sure you have all the plugs in the right order?
Old 09-12-2005, 10:01 AM
debo*'s Avatar
Default Re: misfiring, stalling and a bright cel whats the problem? (EK4doorcivic)
blow your plug holes out with air, maybe water or liquid or something is in there or dirt, also check the spark plugs if they are arcking by seeing if there is any black/white marks or damage.
Old 09-12-2005, 11:54 AM
.Kevin.'s Avatar
Default Re: misfiring, stalling and a bright cel whats the problem? (debo*)
my plugs are really white as in im running lean or hot.... and yes all the plugs are in the rite order i havent messed with them before this problem started happening
Old 09-12-2005, 12:00 PM
kkim's Avatar
Have the O2 sensor replaced first and see if that clears your codes before you do anything else.
Old 09-12-2005, 12:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 &raquo;</TD></TR><TR><TD CLASS="quote">my plugs are really white as in im running lean or hot.... and yes all the plugs are in the rite order i havent messed with them before this problem started happening</TD></TR></TABLE>
Then definitely replace that O2.......like I said it will cause you to run rich as hell....and give you misfire like syptoms.
Does it run okay under throttle? Mine did.
Old 09-12-2005, 12:51 PM
.Kevin.'s Avatar
Default Re: misfiring, stalling and a bright cel whats the problem? (undertheradar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undertheradar &raquo;</TD></TR><TR><TD CLASS="quote">
Does it run okay under throttle? Mine did.</TD></TR></TABLE>
it has its moments like this morning when i was getting ready to take it to school under full throttle it studdered so i let it sit at home and then when i got home 2 hours later i took it out for a spin and it didnt hesitate once
AJMarshall
02-15-2016 12:01 AM
fryman
01-13-2011 03:44 PM
Eighty-Nyne
09-10-2008 09:37 AM
itrdriver1071
05-14-2005 08:18 AM
stehigs321
13
03-18-2004 05:10 AM
Quick Reply: misfiring, stalling and a bright cel whats the problem?
