NEED HELP....Alternator went out..now codes are on and sensors are bad..b16A
2 weeks ago I was driving on the freeway when I noticed that my CEL went on and my speedometer wasnt working. Couple minutes after that I started losing power...fist my radio went out and then my lights started dimming. Pulled over..car idled for a couple minutes and then died. I replaced the battery and alternator and the started up and hasnt died since. My CEL light is still on and my speedo still didnt work. I had a code 20 and 41...electical load detector and heater in the primary O2 sensor. Put in a used o2 sensor and that didnt work. And i also noticed that I keep blowing the fuse to the alternator/SP sensor. Any advice that you guys could give me would be awesome..thanks.
Re: NEED HELP....Alternator went out..now codes are on and sensors are bad..b16A (EKcoupe99)
Correct, The ELD will dectect a high/low voltage due to the alternator failing. And also that intern makes the o2 sensor get the incorrect voltage. But also, check for any shorting in the wiring harness.
JLCustomizing
Honda Civic (2001 - 2005)
01-21-2016 05:07 AM
Montague
11
12-23-2014 04:44 AM
