grr... front end smacked the ground... speedbump!
hello ht'ers...
so today i was getting out of the mall like i always do. im driving at about 30mph, and i always go over this speedbump at this speed. however, today as i go over the speedbump i hear a loud THWACK! and my front end proceeds to slam towards the ground.
now im kinda worried, could i have possibly damaged anything? i kinda went down to check, but it was too dark to see anything. i know theres a big plastic thing to prevent rocks or pebbles from hopping up into the engine bay, but other than that, what else is down there?
thanks.
thanks.
Re: grr... front end smacked the ground... speedbump! (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 »</TD></TR><TR><TD CLASS="quote">so today i was getting out of the mall like i always do. im driving at about 30mph, and i always go over this speedbump at this speed.</TD></TR></TABLE>
jesus, i hope its not a big bump...
everything should be good... if you have an oil spot or coolant spot under your car in the morning you should worry a little bit, but if its dry i wouldnt fret...
Re: grr... front end smacked the ground... speedbump! (fwdtamiya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fwdtamiya »</TD></TR><TR><TD CLASS="quote">Header and oil pan are most likely banged up a little. I'm pretty sure you'll be fine.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 »</TD></TR><TR><TD CLASS="quote">headers the most if ur an unlucky person but shouldn' be a big deal if anything at all</TD></TR></TABLE>\
Headers is anything, i've seen headers into the oil pan. But if anything you just flatened out the headers
Chances are it hit the frame and that was all, just jack it up and take a look tomarrow you should be fine tho.
Re: (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 »</TD></TR><TR><TD CLASS="quote">there was already an oil spot under there when i bought it
so if there is a coolant spot... what should i do? </TD></TR></TABLE>
make sure you didnt bump one of the hoses loose.
