Oil leak need help asap gotta drive it 300 miles in 5 days
Old 09-11-2005, 11:37 AM
BoostedEgHatchFl's Avatar
Default Oil leak need help asap gotta drive it 300 miles in 5 days
I have a mini me in a eg hatch. A6 bloack Y8 head. I was driving down the street and a brick/big *** rock fell out of a truck infront of my. There was no where to go so I hit it. It fucked my oil pan up in the middle. I replaced it and the oil pan gasket. Well I figured out that its the oil pump front seal leaking. Where the crank goes through it. So I replaced it and its still leaking. I order a new seal and it will be here tomorrow. If there any RIGHT was to put it in so it doesn't leak, I have 80 psi on oil at start up and after it warms up it idles ar 19-25 psi. When I'm in 5th gear going 60 its at like 40-55 psi. So I know my pump is good but I can't stop that seal from leaking. Please help I need to get it fixed tomorrow.
Thanks alot,
Chris
Old 09-11-2005, 11:42 AM
Global Moderator
Jimmy's Avatar
When replacing the oil pan gasket, use honda bond or some sort of gaskets sealer and don't over torque the nuts because it will put uneven pressure on the seal and cause leaks..
Old 09-11-2005, 11:59 AM
Default Re: (Jimmy)
http://www.hondaautomotivepart...AINER
Its part # 22 thats leaking I put a new one on and its leaking now
Ralph3991
01-11-2013 07:18 PM
keychild486
03-01-2009 04:44 PM
Quickridez_3
05-01-2008 12:17 AM
steinar
07-19-2006 12:11 PM
BoostedEgHatchFl
11
09-13-2005 08:17 PM
Quick Reply: Oil leak need help asap gotta drive it 300 miles in 5 days
