Do i Need a complete Swap???
Hi guys . I have a 1997 Honda Civic with the Stock engine coded d16y8. One of my piston rods got messed up so is messed up. So im shepping for a new motor. Now i was wodering since the b16 engine is still a 1.6 could i fit it with my trnasmission that i have now on my d16y8 engine? So in terms do i NEeed to switch my tranny or can i just replace it with the b16 and it will pop into place?
Re: (sXekid)
you will need a new engine, tranny, axles, shift linkage, etc. from a b-series
You have a good ECU though, so instead of using that send it off to get chipped for a b-series
Re: Do i Need a complete Swap??? (scarface50370)
i would definately go with a b-series. more options that a sohc 1.6. usually when you buy a complete swap it comes with everything. that way you don't have to worry about much. try this website:
[www.nippon-motors.com][/http://www.nippon-motors.com]
[http://www.jspecautosports.com/] [/http://www.jspecautosports.com/default.aspx]
Re: (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">You have a good ECU though, so instead of using that send it off to get chipped for a b-series</TD></TR></TABLE>
1997 with y8 is obd2. He'll want an obd1 sohc vtec (p28) ecu for chipping.
Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">
1997 with y8 is obd2. He'll want an obd1 sohc vtec (p28) ecu for chipping. </TD></TR></TABLE>
you are right...forgot anout that
hondatuner020
12
04-11-2007 07:11 AM
Kod Sol
05-25-2005 06:48 AM
