What will fix this?
What will fix this?
I have a 93 hatch with Tien Springs, rear disk conversion, kyb struts, GSR fat 5 wheels. After my rear disk conversion when I turn the corners the wheel scrapes horribly, both sides. It's not too bad when it's just me but the other day I went to the mountains and had some people in the back and every corner was bad. I have a rear camber kit should I just bring in the tops alittle or will lower control arms fix my problem?
Re: What will fix this? (Spoon_Fed_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon_Fed_EM1 »</TD></TR><TR><TD CLASS="quote">did you do an alignment? You might have a rear camber kit but it's useless w/ out an alignment</TD></TR></TABLE>
Exactly. Camber kits just allow more flexibility with alignments, but are useless without the actual alignment.
Re: What will fix this? (EK4doorcivic)
What exactly is involved with doing that? How much does it cost?
No I havent done my alignment yet was wondering if I should get the Billet lower control arms then do the alignment? I have heard that you only need a baseball bat to roll the fenders is that true?
Re: What will fix this? (B20badboy)
Yea you can you use the baseball bat.. But it't kinda ghetto but it works. How I do it is jack up the car and put the baseball bat in the center of the wheel well and lower the jack. then spin the bat around the wheel well. Hope that helps..
chjkingme
11
04-14-2013 03:44 PM
94AccordSedanEX
10-16-2003 08:54 PM
