4 alternators killed ... on 5
since i have got my car.. about a year and a half
and i have been through 4 alternators and im gonna be on my fifth
i figured before that the alternators were bad.. but this is kidna rediculous
when i got my car i had the battery light on but i replaced the alternator and it went away
then my alternators lasted about a few months a peice and then they just die
my interior lights are dim but that seems to happen in a lot of civics
so i wasnt worried..
my question is why does my car eat through alternators?
Re: (JDMlyfestyle)
no my car is completely stock
doesnt even have a radio
i got them all off h-t used
and i thought it might be because they are used but this is a lotta dead alternators
for not that long of a period of time
and no rewiring
and no rewiring
maybe a short that is only connected when the engine is "on" i.e. your alternator would be doing about 110% all the time. Try sticking a amperemeter on it when the engine is running and see how much it draws.
good luck.
good luck.
1 Post
Re: 4 alternators killed ... on 5 (egcivic)
bring it to and alternator shop they will tell you whats wrong with it and bring your old ones as well if they are all failing from the same problem it might be your car, also a shop can just replace the voltage regulator or diode rectifiers if thats all that is bad
If you have access to a VAT-40, like if you have a friend in a dealership or shop somewhere, use it instead of an ammeter. It will show you everything you will ever need to know about what your alternator is doing, and more. If you have to use an ammeter on an alternator, make sure you know what you are doing, or have a friend that does. Other wise you could possibly fry your alternator, your voltage regulator, or even a major computer component. Because alternators use diodes so that you don't get alternating currents (AC voltage) through your electrical components. That can lead to a lot of problems for your circuitry. If you need some specific information on how to use the ammeter, let me know, I can walk you through it step by step later if you need. Good luck!
Re: (dohcVTECeg2)
i was thinking that it was a short in my wiring or something also...
but i am not sure..
and i dunno but does a bad battery fry an alternator?
and as of currently my alternator is dead so there is no use testing it
but when i get a new one (thinking of going with a warrantied one becuase considering the history of alternators with my car it will die soon) i do want to fix the problem so i would test the alternator with an ammeter becuase i dont have a freind that would have access to a vat-40, and then test all my wiring and grounds?
i was thinking this was what i needed to do.. but i wanted to just make sure before i went ahead and went throught everything
but i am not sure..
Re: (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">you sure you dont need a new battery</TD></TR></TABLE>
Exactly, sounds like youve been changing out the wrong part. If your powering a somewhat dead batt, then it will kill out you alts. Replace the batt.
Re: (Luserkid)
yea but wouldn't he know if he had a bad battery? Like starting problems and everything. I know I sit there sometimes with the engine off and just listen to the radio on lunch break and stuff... A bad batt. couldn't do that and then be able to start too could it? I would say check your grounds too.
Re: (alleyezonme)
you definatly have a wriring issue.
unless you are just buying jacked up alternators, why else would someone sell an alternator becasue they needed a new one so they sold you the old one that needed replacing.
at least shell out the money for a refurbished one that has a year warrenty so you can get another one if it dies.
take it to a shop and get a charging systems check and they can tell you how much current the alt. is drawing and how much its putting out
Re: (built562)
yea i figure that is the best way to go right now
and i think im going to get a warrantied one tommorow
and i never thought of buying used that way but yea
im gonna go get a new one that start looking at wiring when its not wet and cold
and is there a certain voltage or anything the battery is supposed to be putting out so i can test it?
do this first off man.
go to ur local electronics store(like frys or radioshack) and get a multimeter.
then go check the voltage on the battery with the car off. if its alot lower than 12, then ur batt is bad.
then check the voltage at the batt with the car running at different times.
if you see it spiking severely high, like 15+ volts,
then ur alt is probably overworking itself for some reason.
multimeters are definetely very handy to have, it's a good idea to get one, you'll find uses for it later on for who knows what! (at the very least they can tell u how much life any battery has in it, haha).
Re: (Tad)
yea my dad has a pretti godo multimeter i think.. well regardless its a multimeter
and i checked the battery with the car on and off a few months ago
and it was liek around 12.7 with it off and aroudn 14 sumthin with it on
so it seemed about right
so i wasnt worried, but my alternator always jus seems to crap out on me
and i jsu changed it for a brand new one warranty and all
so i guess ill check it now that the car is running
it doesnt seem liek i have a bad battery becasue even after the alternator died and i was driving it home on the battery
it still started up without a jump after the new alternator was in
but ill go ahead and check the voltage again
im not srue but i beleive its supposed to be high 12's with it off and high 14's with it on?
1 Post
standard is 12.5 off, 13.8 - 14.4 with no load while engine is running at 2000 rpm. while engine is idle, the voltage should not drop under 12.5 with no load. a bad battery, ecu, grounds, shorts, will kill an alt.
JokerTypeR
29
05-14-2005 01:52 PM
