GSR ECU = SOHC VTEC ENGINE
Re: GSR ECU = SOHC VTEC ENGINE (ThatOneOG)
You gonna have a check engine light on, cause the gsr ecu is looking for knock sensor and IABS.
Your rev limiter will be set too high, and unless you have upgraded valvetrain, you've got the potential to start floating valves.
Lastly, Im not sure what the vtec engaugment point is on a sohc, but its likely that with the gsr ecu, it will egauge too high.
slammeddelsol95
10-02-2004 07:22 AM
