QUICK HELP -- What is the size of the allen bolts on the Skunk2 front camber kit!
I am retarded and only own standard allen wrenches. Which size wrench should I go buy to fix my camber kit.
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: QUICK HELP -- What is the size of the allen bolts on the Skunk2 front camber kit! (Si Shane)
i would replace thos bolts with grade 10.9 hex head (10mm) bolts. the thread is 6x1.00 mm. you can then use a torquewrench and torque them properly. personally i use threadlocker and torque them to 10ft/lbs.
Re: QUICK HELP -- What is the size of the allen bolts on the Skunk2 front camber kit! (whoDAT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">i would replace thos bolts with grade 10.9 hex head (10mm) bolts. the thread is 6x1.00 mm. you can then use a torquewrench and torque them properly. personally i use threadlocker and torque them to 10ft/lbs. </TD></TR></TABLE>
Thanks, I had planned to change out the bolts once I figured out that they are 6x1.0 mm. I can now find the right allen wrench to back those suckers out, and look forward to using my new camber gauge! Woot!
euG3dc2r
05-01-2007 06:14 PM
Slammed Ek9
10
08-08-2005 10:15 AM
