NEED URGENT HELP... 94 Civic SRS fault
My brother in law and I just swaped engines in a 94 honda civic. The engines are the same. We have a SRS fault that is comming up. One long flash and one quick flash. Can anyone help?
Re: NEED URGENT HELP... 94 Civic SRS fault (Ghostkoi01)
As I remeber you need to find the yellow 2 pin plug under the dash, this need to be looped.
1. Jump the yellow connector with wire
2. Turn on acc. power on vehicle
3. wait till SRS light goes off
4. Dissconnect one side of jumper
5. Wait till light comes on
6. Connect jumper again
7. Wait till light goes off and you should be all ready to go unless there actually is a real problem.
Check Continuity between the cable reel and the Air bag plug. The Cable reels break all the time.
