Disconnecting shift linkage in EK need help (pics)
Old 12-22-2005, 07:11 PM
'Lude01's Avatar
Default Disconnecting shift linkage in EK need help (pics)
Me and my buddy are trying to disconnect the shift linkage in his EK, so we don't know how to disconnect this part circled in white.
view from the top
Old 12-22-2005, 07:15 PM
xhatchracerx's Avatar
Default Re: Disconnecting shift linkage in EK need help ('Lude01)
so you have met Mr. Bitch Pin lol, get a punch and hammer it out
Old 12-22-2005, 07:24 PM
RocknRon's Avatar
Default Re: Disconnecting shift linkage in EK need help (xhatchracerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xhatchracerx &raquo;</TD></TR><TR><TD CLASS="quote">so you have met Mr. Bitch Pin lol, get a punch and hammer it out</TD></TR></TABLE>
Old 12-22-2005, 07:29 PM
adictionbass's Avatar
Default Re: Disconnecting shift linkage in EK need help (Curry king)
has anyone broken anything hitting out that pin?? i always hit it like a poon box so i dont break the tranny case
Old 12-22-2005, 08:22 PM
dohcVTECeg2's Avatar
Default Re: Disconnecting shift linkage in EK need help (adictionbass)
Mr. Bitch Pin. thats funny
Old 12-23-2005, 10:52 AM
Br1anPham's Avatar
Default Re: Disconnecting shift linkage in EK need help (dohcVTECeg2)
air hammer.
Old 12-23-2005, 10:54 AM
1337 Si's Avatar
Default Re: Disconnecting shift linkage in EK need help (Br1anPham)
I have 4 extra pins cuz I end up SOMEHOW flaring it out.
Old 12-23-2005, 10:59 AM
spoolin_si's Avatar
Default Re: Disconnecting shift linkage in EK need help (1337 Si)
punch and hammer....air hammer is the **** though!!!! nah never broken anything hit it with some nuts!
Old 12-23-2005, 11:10 AM
SOHCD16y8's Avatar
One of the bolts that holds on the A/c compressor fits in there perfect. Never fails
Old 12-23-2005, 11:24 AM
1337 Si's Avatar
Default Re: (SOHCD16y8)
That could always come out or break. IT isn't ahrdened steel.
Old 12-23-2005, 12:06 PM
senpai's Avatar
Default Re: (1337 Si)
http://www.geocities.com/senpa....html
Old 12-23-2005, 12:11 PM
skunk2eg's Avatar
Default Re: (senpai)
teh bastard pin, ah memories
Old 12-23-2005, 12:58 PM
'Lude01's Avatar
Default Re: (skunk2eg)
thanks guys, we can now continue with the swap
Old 12-23-2005, 04:58 PM
u2civic1's Avatar
Default Re: ('Lude01)
worst come to worst pull the motor out with the linkage
Old 12-23-2005, 05:31 PM
4dohs4mohoes's Avatar
Default Re: (u2civic1)
Yeah that pin sucks my anus. I have taken it out with an air hammer and flared ther end so be careful. I'd just pull the motor with it attached and then take it off. Much easier.
Old 12-23-2005, 06:06 PM
Ricey McRicerton's Avatar
Default Re: (boo bees)
I always drop it with the tranny and usually a few hits with my "thor hammer" (mini sledge) gets it out pretty quick.
To answer the question about anyone breaking anything outing it. I've whacked the **** out of my hands thinking I broke them before I wised up and realized it was easier to just get it out with the tranny.
Old 12-23-2005, 07:35 PM
hutch311's Avatar
Default Re: (Ricey McRicerton)
you need a roll pin punch
Old 12-23-2005, 07:45 PM
Mr. JDM-GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">has anyone broken anything hitting out that pin?? i always hit it like a poon box so i dont break the tranny case </TD></TR></TABLE>
nuffin broken but i alot of loose dirt in my eye
Old 12-24-2005, 01:58 PM
turbo90crx's Avatar
Default Re: Disconnecting shift linkage in EK need help (Mr. JDM-GSR)
pulling the motor with the linkage attached is a good idea but you really have to be careful the you dont bend it if it gets caught between the floor and the rear crossmember, ive had a problem with the "bitch pin" more times than you can imagine, i usually just drill it out and replace with a new one i keep like 5 on hand...lol
Old 12-24-2005, 02:04 PM
navin's Avatar
Default Re: Disconnecting shift linkage in EK need help (turbo90crx)
EG airbox bolts also work perfectly + 8 lb sledge
Old 12-25-2005, 11:14 AM
HeikDiesel's Avatar
Default Re: Disconnecting shift linkage in EK need help (navin)
Anyone ever measured it to see what size of punch would be the correct tool to use for it? 8mm?
Old 12-25-2005, 01:11 PM
navin's Avatar
Default Re: Disconnecting shift linkage in EK need help (PhatAcuraIntegra)
I belive 8mm tapered? not positive, use the airbox bolt!!
MURDOCSgarage
06-05-2008 07:33 PM
RACEPAK
08-04-2006 10:44 AM
atsyuo
08-24-2005 11:43 AM
B2FiNiTY
11-13-2004 06:51 PM
Quick Reply: Disconnecting shift linkage in EK need help (pics)
