H22 downpipe hitting oil pan!!
I just replaced my 93 h22 block with a 00 h22 block. I am still using the 93 downpipe that fit perfectly on my old block, but when I try to install it on the new one it hits the 00 oil pan!! I searched and found a couple posts that i could swap out the oil pans and put the 93 on the 00, but i was wondering if there was another way.
Also does anyone know for sure if I can swap pans??
Re: H22 downpipe hitting oil pan!! (alleyezonme)
Well, the only other fix I can think of is to buy the 5th gen H22 exhaust manifold, but that will be more expensive.
Do you have access to a lift? If you do, just get under there and and take the pan off. You have to remove the clutch shield plate before you can get to the oil pan, but I think that's it. Not hard.
Obviously, you'll lose all your oil when you take the pan off, but it's good to replace your oil and oil pan gasket anyways.
And you will find the answer to your question.
my two cents....
my two cents....
Re: H22 downpipe hitting oil pan!! (preludepower)
yea i put this thread up in the prelude forum and they said it def. works but when I did it mine hit the oil pickup thing, but mine was pretty banged up... So right now i am banging on it and prolly pissing off the neighbors! So my other question is then how much clearence do i need between the oil pickup and the bottom of the pan??
not very much...on my car they almost touch...they both get very hot anyways, so I don't think it matters if they do touch...
I am more worried about the pickup not being able to pickup enough oil becuase the opening is resting on the pan.
