car doenst move
car doenst move
i just finish my motor swap. new motor, tranny and clutch. last night, i drove it a bit to see if everything was alright. it was good to go. just amoment ago, i tried to drive it again, put it into gear, but doesn't move. the motor just revs....
Re: car doenst move (Frosty R81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frosty R81 »</TD></TR><TR><TD CLASS="quote">i just finish my motor swap. new motor, tranny and clutch. last night, i drove it a bit to see if everything was alright. it was good to go. just amoment ago, i tried to drive it again, put it into gear, but doesn't move. the motor just revs....</TD></TR></TABLE>
with out pressing the clutch slowly, gently, and carefully try to put it from neutral into first. If it lets you it means that your clutch is stuck for some reason or you are not getting it into gear.
Does it feel like it is in gear?
if you have it in first with the engine off can you push the car forward?
have you tried the other gears?
good luck
good luck
Re: car doenst move (old man neri)
start it in gear with the clutch down, it starts up. tried to drive but nothing. but i can change gear without stepping on teh clutch with ease...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frosty R81 »</TD></TR><TR><TD CLASS="quote">start it in gear with the clutch down, it starts up. tried to drive but nothing. but i can change gear without stepping on teh clutch with ease...</TD></TR></TABLE>
Then either your clutch is not disengaging or your shifter linkage is fucked and you are not actually getting it into any gear. If it feels like you are in gear though (that feeling of the notches in the shifter when shifting) then it's probably your clutch or anything else going from your engine to the tranny.
Hope that helps a little and bump for someone else to give a hand cause I am at my end.
seeeya04
18
10-23-2023 02:43 PM
creepy116
14
12-19-2007 05:23 AM
GDM93Si
18
05-28-2007 05:45 PM
f22b2tdave
02-27-2005 02:02 PM
