Obd2 - ob1 si swap helpp
Obd2 - obd1 si swap helpp
Already searched and didnt come up with what i neede to hear. I plan on getting a motor swap in the near future for my 99 si. I also plan on running boost and running hondata. My problem is though i want to pass emissions. is there any way i could run and obd2 motor, with a conversion harness to obd1 with a chipped ecu with hondata. Or can i just buy an obd 1 motor and have an obd2 ecu to make it pass. Please help.... thanks for you time and merry christmass
There isn't a stock OBD2B ECU oriented EMS that would pass emissions, other than a piggy back off the stock ecu.
But if you just do a swap and run the a OBD2B ecu, it will pass inspection/emission.
It is either convert to OBD1 and run uberdata/crome/hondata (all the same idea) and run a conversion harness.. then when inspection comes pop in a stock OBD2 ecu to pass it with.
Or get AEM and do the same thing when inspection comes around.. or run a piggy back off the OBD2 ecu.
My vote goes to the first.. convert to OBD1.
Re: (Ninefivejiggaja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninefivejiggaja »</TD></TR><TR><TD CLASS="quote">alright thanks for your help, when i need a chipped p28 im a call you my friend, thanks</TD></TR></TABLE>
no problem
no problem
