just did a valve adjustment...(B series)
well i just finished doing a valve adjustment on my B18C'd civic and i still hear clicking, but now i can't remember if its the same or if it louder or quieter. how loud do the injectors usually click? is there anyway of telling i adjusted everything correct?
i'm tryin to save money around christmas and tried to do this by myself using cspeeds writeup(which is a very good one) but now how can i double check?
Re: just did a valve adjustment...(B series) (untitledsn41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitledsn41 »</TD></TR><TR><TD CLASS="quote">well i just finished doing a valve adjustment on my B18C'd civic and i still hear clicking, but now i can't remember if its the same or if it louder or quieter. how loud do the injectors usually click? is there anyway of telling i adjusted everything correct?
The injectors are fairly loud, but not too bad. You can stick a screwdriver on them and put your ear to the end of the screwdriver to hear if you wish. I use this cheap method of making a mechanics stethescope to pinpoint noises all the time. Its actaully quite accurate. You can also put the screw driver over the exhaust ports and intake ports and find noisy valves as well. Remember, its going to make SOME noise, thats just how it is. A certain amount of clicking is acceptable. Did you do the valve adjustment with the head temperature below 100 degrees?
on b series you will have some clicking, almost all b's have clicking from what ive heard
Re: just did a valve adjustment...(B series) (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">The injectors are fairly loud, but not too bad. You can stick a screwdriver on them and put your ear to the end of the screwdriver to hear if you wish. I use this cheap method of making a mechanics stethescope to pinpoint noises all the time. Its actaully quite accurate. You can also put the screw driver over the exhaust ports and intake ports and find noisy valves as well. Remember, its going to make SOME noise, thats just how it is. A certain amount of clicking is acceptable. Did you do the valve adjustment with the head temperature below 100 degrees?</TD></TR></TABLE>
i drove my car for about 10 minutes when it was like 40 degrees outside and when i got back home the needle on the temp gauge was barely over that bottom line. i then let it sit for about 5 hours so i'm sure it was under 100degrees,
i think it's good i'll compare with some buddies at school and see how theirs sounds i guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman »</TD></TR><TR><TD CLASS="quote">on b series you will have some clicking, almost all b's have clicking from what ive heard</TD></TR></TABLE>
yeah i've heard that too but have never known how much clicking their should be
thanks for the input
Re: just did a valve adjustment...(B series) (postman)
not if you are running stock cams. it should sound pretty quiet. way i usually do mine is tighten it until the srew stops (do it lightly), and then back it out a 1/4 turn.
Re: just did a valve adjustment...(B series) (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">not if you are running stock cams. it should sound pretty quiet. way i usually do mine is tighten it until the srew stops (do it lightly), and then back it out a 1/4 turn.</TD></TR></TABLE>
thats what i did but i still get clicking
i'm just worried i f'd something up. i triple checked it thuogh
You don't use feeler gauges? This is a pretty dangerous way to adjust valves if you ask me.
ha i used the feeler gauges. idk about him.
but i tightened it til the feeler gauge was stuck then slowly loosend the screwdriver while moving back and forward the feeler gauge.
teamvirus
10
10-22-2006 07:30 PM
GSRVTEC1
11-09-2005 07:26 PM
deconstruct
23
06-29-2004 09:31 AM
